A method for grouping synonyms. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we present a method for merging several synonym dictionaries and a general purpose dictionary, thus permitting both an increased synonymic coverage of the general lexicon and the enrichment of the synonym lexicon with part of speech and definitional information that are lacking in the original synonym dictionaries. The method uses gloss based similarity measures, often employed to disambiguate words in context, to map the synonyms of a verb to the definitions associated with that verb in a large machine readable dictionary. The results are evaluated with respect to a hand-built reference. Furthermore, we explore ways towards using this method in combination with translation and ontology enrichment techniques to enrich our synonym lexicon and align it with the Princeton/EuroWordNet.
eLex_falk_ingrid_revised.pdf (38.81 Ko) Télécharger le fichier
slides.pdf (430.74 Ko) Télécharger le fichier
Format : Autre
inria-00424897 , version 1 (19-10-2009)
  • HAL Id : inria-00424897 , version 1
Ingrid Falk, Claire Gardent, Evelyne Jacquey, Fabienne Venant. A method for grouping synonyms.. eLexicography in the 21st century (eLex 2009), Centre for English Corpus Linguistics (CECL) under the aegis of the European Association for Lexicography (EURALEX), Oct 2009, Louvain-la-Neuve, Belgium. ⟨inria-00424897⟩
143 Consultations
484 Téléchargements
