inria-00426041, version 1
Modeling Macro-Molecular Interfaces with Intervor
Frederic Cazals
1Sebastien Loriot
1
N° RR-7069 (2009)
Résumé : Intervor is a software computing a parameter free representation of macro-molecular interfaces, based on the alpha-complex of the atoms. Given two interacting partners, possibly with water molecules squeezed in-between them, Intervor computes an interface model which has the following characteristics: (i) it identifies the atoms of the partners which are in direct contact and those whose interaction is water mediated, (ii) it defines a geometric complex separating the partners, the Voronoi interface, whose geometric and topological descriptions are straightforward (surface area, number of patches, curvature), (iii) it allows the definition of the depth of atoms at the interface, thus going beyond the traditional dissection of an interface into a core and a rim. These features can be used to investigate correlations between structural parameters and key properties such as the conservation of residues, their polarity, the water dynamics at the interface, mutagenesis data, etc. Intervor can be run from the web site http://cgal.inria.fr/abs/Intervor , or in stand-alone mode upon downloading the binary file. Plugins are also made available for Visual Molecular Dynamics (VMD) and Pymol.
- 1 : ABS (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Géométrie algorithmique
Sciences du Vivant/Bio-Informatique, Biologie Systémique
Informatique/Bio-informatique - Mots-clés : Union of balls – Voronoi diagrams – alpha-shapes – proteins – macro-molecular complexes – interfaces – structural biology
- Référence interne : RR-7069
- inria-00426041, version 1
- http://hal.inria.fr/inria-00426041
- oai:hal.inria.fr:inria-00426041
- Contributeur : Frederic Cazals
- Soumis le : Lundi 26 Octobre 2009, 10:40:42
- Dernière modification le : Vendredi 18 Décembre 2009, 15:57:08
Documents associés
Exporter
