Comparison between Boolean and piecewise affine differential models for genetic networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Multi-level discrete models of genetic networks, or the more general piecewise affine differential models, provide qualitative information on the dynamics of the system, based on a small number of parameters (such as synthesis and degradation rates). Boolean models also provide qualitative information, but are based simply on the structure of interconnections. To explore the relationship between the two formalisms, a piecewise affine differential model and a Boolean model are compared, for the carbon starvation response network in E. coli. The asymptotic dynamics of both models are shown to be quite similar. This study suggests new tools for analysis and reduction of biological networks.
RR-7070.pdf (287.93 Ko) Télécharger le fichier
inria-00426414 , version 1 (26-10-2009)
  • HAL Id : inria-00426414 , version 1
  • PRODINRA : 246522
Madalena Chaves, Laurent Tournier, Jean-Luc Gouzé. Comparison between Boolean and piecewise affine differential models for genetic networks. [Research Report] RR-7070, INRIA. 2009, pp.23. ⟨inria-00426414⟩
183 Consultations
76 Téléchargements
