Cosine Effect in Ocean Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series B Année : 2010
This works aims at studying the impact of the cosine terms of the Coriolis force, that are usually neglected in geophysical fluid dynamics, leading to the so-called traditional approximation. Mathematical well-posedness arguments for simplified models, as well as numerical simulations, are presented in order to suggest the use of these terms in large scale ocean modelling.
Lucas_Rousseau_HAL.pdf (407.29 Ko) Télécharger le fichier
inria-00428977 , version 1 (30-10-2009)
inria-00428977 , version 2 (11-02-2010)
Carine Lucas, Antoine Rousseau. Cosine Effect in Ocean Models. Discrete and Continuous Dynamical Systems - Series B, 2010, Special Issue on Oceanography and Mathematics, Paris, France 26-28 January 2009, 13 (4), pp.841-857. ⟨10.3934/dcdsb.2010.13.841⟩. ⟨inria-00428977v2⟩
335 Consultations
362 Téléchargements
