How to Tackle Integer Weighted Automata Positivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper is dedicated to candidate abstractions to capture relevant aspects of the integer weighted automata. The expected effect of applying these abstractions is studied to build the deterministic reachability graphs allowing us to semi-decide the positivity problem on these automata. Moreover, the papers reports on the implementations and experimental results, and discusses other encodings.
rp09_submission.pdf (839.13 Ko) Télécharger le fichier
inria-00428998 , version 1 (30-10-2009)
Yohan Boichut, Pierre-Cyrille Heam, Olga Kouchnarenko. How to Tackle Integer Weighted Automata Positivity. 3rd InternationalWorkshop on Reachability Problems - RP 2009, Sep 2009, Palaiseau, France. pp.79-92, ⟨10.1007/978-3-642-04420-5_9⟩. ⟨inria-00428998⟩
206 Consultations
87 Téléchargements
