Combining a Mass Matrix formulation and a high order dissipation for the discretisation of turbulent flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
This study focuses on analysis of a mass matrix scheme with high-order numerical dissipation for the discretisation of three-dimensional turbulent flows.We used a mixed finite element/finite volume formulation for the discretisation of compressible Navier-Stokes equations.VMS-LES turbulence model is performed to simulate the flow around a circular cylinder at a subcritical Reynolds number of 3900.
RR-7079.pdf (564.01 Ko) Télécharger le fichier
inria-00429062 , version 1 (30-10-2009)
  • HAL Id : inria-00429062 , version 1
A. Belme, H. Ouvrard. Combining a Mass Matrix formulation and a high order dissipation for the discretisation of turbulent flows. [Research Report] RR-7079, INRIA. 2009, pp.32. ⟨inria-00429062⟩
61 Consultations
43 Téléchargements
