Traffic Grooming on the Path - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In a WDM network, routing a request consists in assigning it a route in the physical network and a wavelength. If each request uses at most 1/C of the bandwidth of the wavelength, we will say that the grooming factor is C . That means that on a given edge of the network we can groom (group) at most C requests on the same wavelength. With this constraint the ob jective can be either to minimize the number of wavelengths (related to the transmission cost) or minimize the number of Add Drop Multiplexer (shortly ADM) used in the network (related to the cost of the nodes). Here we consider the case where the network is a path on N nodes, PN . Thus the routing is unique. For a given grooming factor C minimizing the number of wavelengths is an easy problem, well known and related to the load problem. But minimizing the number of ADM's is NP-complete for a general set of requests and no results are known. Here we show how to model the problem as a graph partition problem and using tools of design theory we completely solve the case where C = 2 and where we have a static uniform all-to-all traffic (requests being all pairs of vertices).
BBC-Sirocco05.pdf (209.54 Ko) Télécharger le fichier
inria-00429172 , version 1 (01-11-2009)
Paternité
Jean-Claude Bermond, Laurent Braud, David Coudert. Traffic Grooming on the Path. 12th International Colloquium on Structural Information and Communication Complexity (SIROCCO), May 2005, Mont Saint-Michel, France. pp.34-48, ⟨10.1007/11429647_5⟩. ⟨inria-00429172⟩
118 Consultations
180 Téléchargements
