Traffic Grooming in Unidirectional WDM Ring Networks: the all-to-all unitary case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We address the problem of traffic grooming in WDM rings with all-to-all uniform unitary traffic. We want to minimize the total number of SONET add-drop multiplexers (ADMs) required. This problem corresponds to a partition of the edges of the complete graph into subgraphs, where each subgraph has at most C edges (where C is the grooming ratio) and where the total number of vertices has to be minimized. Using tools of graph and design theory, we optimally solve the problem for practical values and infinite congruence classes of values for a given C . Among others, we give optimal constructions when C ≥ N (N − 1)/6 and results when C = 12. We also show how to improve lower bounds by using refined counting techniques, and how to use efficiently an ILP program by restricting the search space.
BCM-ONDM03.pdf (192.26 Ko) Télécharger le fichier
inria-00429175 , version 1 (01-11-2009)
  • HAL Id : inria-00429175 , version 1
Jean-Claude Bermond, David Coudert, Xavier Munoz. Traffic Grooming in Unidirectional WDM Ring Networks: the all-to-all unitary case. 7th IFIP Working Conference on Optical Network Design & Modelling (ONDM), 2003, Budapest, Hungary. pp.1135-1153. ⟨inria-00429175⟩
169 Consultations
70 Téléchargements
