Traffic Grooming in Unidirectional Wavelength-Division Multiplexed Rings with Grooming Ratio C = 6 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Discrete Mathematics Année : 2005
SONET/WDM networks using wavelength add-drop multiplexing can be constructed using certain graph decompositions used to form a grooming, consisting of unions of primitive rings. The cost of such a decomposition is the sum, over all graphs in the decomposition, of the number of vertices of nonzero degree in the graph. The existence of such decompositions with minimum cost, when every pair of sites employs no more than $\frac{1}{6}$ of the wavelength capacity, is determined with a finite number of possible exceptions. Indeed, when the number N of sites satisfies $N \equiv 1 \pmod{3}$, the determination is complete, and when $N \equiv 2 \pmod{3}$, the only value left undetermined is N = 17. When $N \equiv 0 \pmod{3}$, a finite number of values of N remain, the largest being N = 2580. The techniques developed rely heavily on tools from combinatorial design theory.
BCC_-DM05.pdf (314.21 Ko) Télécharger le fichier
inria-00429214 , version 1 (01-11-2009)
Jean-Claude Bermond, Charles J. Colbourn, David Coudert, Gennian Ge, Alan C. H. Ling, et al.. Traffic Grooming in Unidirectional Wavelength-Division Multiplexed Rings with Grooming Ratio C = 6. SIAM Journal on Discrete Mathematics, 2005, 19 (2), pp.523-542. ⟨10.1137/S0895480104444314⟩. ⟨inria-00429214⟩
226 Consultations
193 Téléchargements
