Inverse EEG source problems and approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2008
We consider the inverse EEG (ElectroEncephaloGraphy) problem that consists in recovering, from measurements on electrodes of the electric potential on the scalp, a distribution of pointwise dipolar current sources located in the brain and modeling e.g. the presence of epileptic foci.
Abstract.leblondpdf.pdf (67.69 Ko) Télécharger le fichier
leblond_.pdf (295.55 Ko) Télécharger le fichier
inria-00430198 , version 1 (06-11-2009)
  • HAL Id : inria-00430198 , version 1
F. Ben Hassen, Maureen Clerc, Juliette Leblond, Stéphane Rigat, M. Zghal. Inverse EEG source problems and approximation. Proceedings of Optimization and Inverse Problems in Electromagnetism (OIPE), Sep 2008, Ilmenau, Germany. ⟨inria-00430198⟩
437 Consultations
138 Téléchargements
