Low-order models : optimal sampling and linearized control strategies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We propose an optimal sampling strategy to build a robust low-order model. This idea is applied to the construction of a vortex wake model accurate for several regimes. In addition we explore the relationships between unstable modes and low-order modelling. An example of control based on a linearized approach is presented.
RR-7092.pdf (537.44 Ko) Télécharger le fichier
inria-00430410 , version 1 (06-11-2009)
  • HAL Id : inria-00430410 , version 1
Edoardo Lombardi, Michel Bergmann, Simone Camarri, Angelo Iollo. Low-order models : optimal sampling and linearized control strategies. [Research Report] RR-7092, INRIA. 2009, pp.32. ⟨inria-00430410⟩
123 Consultations
337 Téléchargements
