Stochastic Behavior and Explicit Discrete Time in Concurrent Constraint Programmin
We address the inclusion of stochastic information into an explicitly timed concurrent constraint process language. An operational semantics is proposed as a preliminary result. Our approach finds applications in biology, among other areas.
Modélisation et simulation
