Benchmarking the Pure Random Search on the BBOB-2009 Noisy Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We benchmark the Pure-Random-Search algorithm on the BBOB 2009 noisy testbed. Each candidate solution is sampled uniformly in $[-5, 5]^{D}$, where $D$ denotes the search space dimension. The maximum number of function evaluations chosen is $10^{6}$ times the search space dimension. With this budget the algorithm is not able to solve any single function of the testbed.
wk2043-Auger.pdf (391.1 Ko) Télécharger le fichier
inria-00430534 , version 1 (08-11-2009)
  • HAL Id : inria-00430534 , version 1
Anne Auger, Raymond Ros. Benchmarking the Pure Random Search on the BBOB-2009 Noisy Testbed. ACM-GECCO Genetic and Evolutionary Computation Conference, Jul 2009, Montreal, Canada. ⟨inria-00430534⟩
102 Consultations
172 Téléchargements
