An Efficient P300-based Brain-Computer Interface with Minimal Calibration Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we propose a new design for P300-based BCI, in order to reduce the calibration time of the system. Our BCI is based on Regularized Canonical Correlation Analysis for feature extraction and Regularized Linear Discriminant Analysis for classification. Evaluations suggested that this design can reach good P300 detection performances while using much less training examples than current approaches, hence effectively reducing the calibration time.
AMD09.pdf (115.76 Ko) Télécharger le fichier
inria-00430563 , version 1 (09-11-2009)
  • HAL Id : inria-00430563 , version 1
Fabien Lotte, Cuntai Guan. An Efficient P300-based Brain-Computer Interface with Minimal Calibration Time. Assistive Machine Learning for People with Disabilities symposium (NIPS'09 Symposium), Dec 2009, Vancouver, Canada. ⟨inria-00430563⟩
321 Consultations
706 Téléchargements
