Extraction of Nom text regions from stele images using area Voronoi diagram - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Automatic processing of images of steles is a challenging problem due to the variation in their structures and body text characteristics. In this paper, area Voronoi diagram is used to represent the neighborhood of connected components in stele images containing Nom characters. Body text region is then extracted from stele images by the selection of appropriate adjacent Voronoi regions based on the information about the thickness of neighboring connected components. Experimental results show that the proposed method is highly accurate and robust to various types of stele.
ICDAR2009.pdf (1.92 Mo) Télécharger le fichier
inria-00430805 , version 1 (10-11-2009)
Thai V. Hoang, Salvatore Tabbone, Ngoc-Yen Pham. Extraction of Nom text regions from stele images using area Voronoi diagram. International Conference on Document Analysis and Recognition - ICDAR'2009, Jul 2009, Barcelona, Spain. pp.921-925, ⟨10.1109/ICDAR.2009.13⟩. ⟨inria-00430805⟩
846 Consultations
244 Téléchargements
