XML Tuple Algebra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2009
XML Tuple Algebra
XML data management requires an algebraic approach. In this work, we describe a unified algebraic approach for modeling computations described by XML queries expressed in an specific, expressive XQuery subset.
Encyclopedia-XMLTupleAlgebra.pdf (502.02 Ko) Télécharger le fichier
inria-00431395 , version 1 (12-11-2009)
  • HAL Id : inria-00431395 , version 1
Ioana Manolescu, Yannis Papakonstantinou, Vasilis Vassalos. XML Tuple Algebra. Ling Liu and Tamer Ozsu. Encyclopedia of Database Systems, Springer, pp.3640-3646, 2009, 978-0-387-35544-3. ⟨inria-00431395⟩
149 Consultations
163 Téléchargements
