Rule-Based Semi Automatic Web Services Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Olivier Perrin
  • Fonction : Auteur
  • PersonId : 830785
Claude Godart
  • Fonction : Auteur
  • PersonId : 830462
  • IdRef : 031091733
In this paper we propose a rule-based approach for the semi-automatic Web services composition problem, giving end-user the control to guide the overall composition process. The end-user builds the composition flow by selecting known Web service instances or constrained Web service types, called nodes, and by connecting them using a set of control/data flow connectors. The specified nodes will then be bound to concrete Web service instances using a set of rule-based queries satisfying the associated constraints. When compared to the traditional approaches, our model is declarative, allows for specifying both the functional and non-functional requirements, provides connectors that include both the data and control flow aspects and aims to choose the one best matched Web service for a node instantiation.
Web
RuleBasedComposition_ICWS.pdf (309.43 Ko) Télécharger le fichier
inria-00431859 , version 1 (13-11-2009)
Ehtesham Zahoor, Olivier Perrin, Claude Godart. Rule-Based Semi Automatic Web Services Composition. 2009 IEEE Congress on Services I - SERVICES 2009, Jul 2009, Los Angeles, CA, United States. pp.805-812, ⟨10.1109/SERVICES-I.2009.77⟩. ⟨inria-00431859⟩
265 Consultations
165 Téléchargements
