SWooki: Un Wiki Sémantique sur réseau Pair-à-Pair - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue des Sciences et Technologies de l'Information - Série ISI : Ingénierie des Systèmes d'Information Année : 2009
Charbel Rahhal
  • Fonction : Auteur
  • PersonId : 842038
Hala Skaf-Molli
Pascal Molli
Wiki systems have evolved in two different ways : semantic wikis and peer to peer wikis. Semantic wikis integrate the semantic web technologies in order to improve their structure, the search and the navigation between pages. Peer-to-peer wikis offer a support for massive collaboration, off-line editing mode and an ad-hoc collaboration. The main challenge in designing a peer-to-peer semantic wiki combining both approaches is the merge of wiki pages embedding semantic annotations. Merging algorithms used in peer-to-peer wiki systems have been designed for linear text. They do not handle semantic data. In this paper, we present SWooki the first peer-to-peer semantic wiki. SWooki combines the advantages of both semantic wikis and peer-to-peer wikis. We detail SWooki approach and its merging algorithm, we insist on its characteristics and its functionalities. We conclude by presenting its architecture and its implementation.
ISI2008.pdf (542.67 Ko) Télécharger le fichier
inria-00432216 , version 1 (14-11-2009)
Charbel Rahhal, Hala Skaf-Molli, Pascal Molli. SWooki: Un Wiki Sémantique sur réseau Pair-à-Pair. Revue des Sciences et Technologies de l'Information - Série ISI : Ingénierie des Systèmes d'Information, 2009, 14 (1), pp.117-140. ⟨10.3166/isi.14.1.117-140⟩. ⟨inria-00432216⟩
197 Consultations
407 Téléchargements
