SemCW: Semantic Collaborative Writing using RST - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Charbel Rahhal
  • Fonction : Auteur
  • PersonId : 842038
Hala Skaf-Molli
Pascal Molli
Nishadi Desilva
  • Fonction : Auteur
  • PersonId : 842039
During collaborative writing each author works on a copy of the shared document. These copies are then merged to produce the final document. This asynchronous work is supported by several collaborative writing tools. While these tools are excellent at merging and detecting syntactic conflicts, they are not able to easily recognise semantic inconsistencies. This hinders the coherence of the document because while each individual copy might be well constructed, they may not be after the merge. To address this, we investigate the combination of the Rhetorical Structure Theory with Operational Transformation approach. In this paper, we define a data model, a set of operations to manipulate the RST structures and a set of transformation functions. A validity checker alerts the authors to areas in the text with possible semantic lapses in the merged documents.
SemCW07.pdf (424.21 Ko) Télécharger le fichier
inria-00432220 , version 1 (14-11-2009)
Charbel Rahhal, Hala Skaf-Molli, Pascal Molli, Nishadi Desilva. SemCW: Semantic Collaborative Writing using RST. The 3rd International Conference on Collaborative Computing:Networking, Applications and Worksharing - CollaborateCom'2007, Nov 2007, New York, United States. pp.484-493, ⟨10.1109/COLCOM.2007.4553879⟩. ⟨inria-00432220⟩
85 Consultations
81 Téléchargements
