An Undo Framework for P2P Collaborative Editing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Stéphane Weiss
  • Fonction : Auteur
  • PersonId : 839033
Pascal Urso
  • Fonction : Auteur
  • PersonId : 830668
Pascal Molli
Existing Peer to Peer (P2P) collaborative editing systems do not al low any user to undo any modification. However, in such systems, users are not aware of others' modifications, hence, they could obtain duplicate work, conflicting modifications or malicious contents. In this paper, we propose a new undo framework called “UNO: Undo as a New Operation” in the Operational Trans- formation approach which does not limit the scalability of P2P algorithms. As a proof of concept, we apply our framework to build a P2P collaborative editor with undo capabilities in which any user can undo any modification.
main.pdf (137.14 Ko) Télécharger le fichier
inria-00432373 , version 1 (16-11-2009)
Stéphane Weiss, Pascal Urso, Pascal Molli. An Undo Framework for P2P Collaborative Editing. 4th International Conference on Collaborative Computing : Networking, Applications and Worksharing - CollaborateCom 2008, Nov 2008, Orlando, United States. pp.529-544, ⟨10.1007/978-3-642-03354-4_40⟩. ⟨inria-00432373⟩
270 Consultations
1862 Téléchargements
