An Early-stopping Protocol for Computing Aggregate Functions in Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we study algebraic aggregate com- putations in Sensor Networks. The main contribution is the presentation of an early-stopping protocol that computes the average function under a harsh model of the conditions under which sensor nodes operate. This protocol is shown to be time-optimal in presence of unfrequent failures. The approach followed saves time and energy by relying the computation on a small network of delegate nodes that can be rebuilt fast in case of node failures and communicate using a collision- free schedule. Delegate nodes run simultaneously two protocols, namely, a collection/dissemination tree-based algorithm, which is shown to be optimal, and a mass-distribution algorithm. Both algorithms are analyzed under a model where the frequency of failures is a parameter. Other aggregate computation algo- rithms can be easily derived from this protocol. To the best of our knowledge, this is the first optimal early-stopping algorithm for aggregate computations in Sensor Networks.
PRDC09.pdf (136.25 Ko) Télécharger le fichier
inria-00432380 , version 1 (16-11-2009)
  • HAL Id : inria-00432380 , version 1
Antonio Fernández Anta, Miguel Mosteiro, Christopher Thraves-Caro. An Early-stopping Protocol for Computing Aggregate Functions in Sensor Networks. Pacific Rim International Symposium on Dependable Computing, Nov 2009, Shanghai, China. ⟨inria-00432380⟩
174 Consultations
227 Téléchargements
