Catch me if you can Looking for type-safe, hierarchical, lightweight, polymorphic and efficient error management in OCaml - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This is the year 2008 and ML-style exceptions are everywhere. Most modern languages, whether academic or industrial, feature some variant of this mechanism. Languages such as Java even feature static coverage-checking for such exceptions, something not available for ML languages, at least not without resorting to external tools. In this document, we demonstrate a design principle and a tiny library for managing errors in a functional manner, with static coverage-checking, automatically-inferred, structurally typed and hierarchical exceptional cases, with a reasonable run-time penalty. Our work is based on OCaml and features monads, polymorphic variants, compile-time code rewriting and trace elements of black magic.
monad.pdf (192.23 Ko) Télécharger le fichier
inria-00432575 , version 1 (16-11-2009)
  • HAL Id : inria-00432575 , version 1
David Teller, Arnaud Spiwack, Till Varoquaux. Catch me if you can Looking for type-safe, hierarchical, lightweight, polymorphic and efficient error management in OCaml. IFL 2008, Sep 2008, Hertfordshire, United Kingdom. 21 p. ⟨inria-00432575⟩
1393 Consultations
2003 Téléchargements
