Drop cost and wavelength optimal two-period grooming with ratio 4
We study grooming for two-period optical networks, a variation of the traffic grooming problem for WDM ring networks introduced by Colbourn, Quattrocchi, and Syrotiuk. In the two-period grooming problem, during the first period of time, there is all-to-all uniform traffic among $n$ nodes, each request using $1/C$ of the bandwidth; and during the second period, there is all-to-all uniform traffic only among a subset $V$ of $v$ nodes, each request now being allowed to use $1/C'$ of the bandwidth, where $C' < C$. We determine the minimum drop cost (minimum number of ADMs) for any $n,v$ and $C=4$ and $C' \in \{1,2,3\}$. To do this, we use tools of graph decompositions. Indeed the two-period grooming problem corresponds to minimizing the total number of vertices in a partition of the edges of the complete graph $K_n$ into subgraphs, where each subgraph has at most $C$ edges and where furthermore it contains at most $C'$ edges of the complete graph on $v$ specified vertices. Subject to the condition that the two-period grooming has the least drop cost, the minimum number of wavelengths required is also determined in each case.
Combinatoire [math.CO]
