Online orientation distribution function reconstruction in constant solid angle and its application to motion detection in high angular resolution diffusion imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The diffusion orientation distribution function (ODF) can be reconstructed from q-ball imaging (QBI) to map the complex intravoxel structure of water diffusion. As acquisition time is particularly large for high angular resolution diffusion imaging (HARDI), fast estimation algorithms have recently been proposed, as an on-line feedback on the reconstruction accuracy. Thus the acquisition could be stopped or continued on demand. We adapt these real-time algorithms to the mathematically correct definition of ODF in constant solid angle (CSA), and develop a motion detection algorithm upon this reconstruction. Results of improved fiber crossing detection by CSA ODF are shown, and motion detection was implemented and tested in vivo.
RR-7102.pdf (477.59 Ko) Télécharger le fichier
inria-00432959 , version 1 (17-11-2009)
  • HAL Id : inria-00432959 , version 1
Emmanuel Caruyer, Iman Aganj, Christophe Lenglet, Guillermo Sapiro, Rachid Deriche. Online orientation distribution function reconstruction in constant solid angle and its application to motion detection in high angular resolution diffusion imaging. [Research Report] RR-7102, INRIA. 2009, pp.12. ⟨inria-00432959⟩
146 Consultations
213 Téléchargements
