L2R: A Logical Method for Reference Reconciliation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The reference reconciliation problem consists in decid- ing whether different identifiers refer to the same data, i.e., correspond to the same world entity. The L2R sys- tem exploits the semantics of a rich data model, which extends RDFS by a fragment of OWL-DL and SWRL rules. In L2R, the semantics of the schema is translated into a set of logical rules of reconciliation, which are then used to infer correct decisions both of reconcilia- tion and no reconciliation. In contrast with other ap- proaches, the L2R method has a precision of 100% by construction. First experiments show promising results for recall, and most importantly significant increases when rules are added.
L2RAAAI07.pdf (127.73 Ko) Télécharger le fichier
inria-00433004 , version 1 (18-11-2009)
  • HAL Id : inria-00433004 , version 1
Fatiha Saïs, Nathalie Pernelle, Marie-Christine Rousset. L2R: A Logical Method for Reference Reconciliation. Twenty-Second AAAI Conference on Artificial Intelligence, Jul 2007, Vancouver, British Columbia, Canada. pp.2007. ⟨inria-00433004⟩
244 Consultations
167 Téléchargements
