Separation of Overlapping and Touching Lines within Handwritten Arabic Documents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Nazih Ouwayed
  • Fonction : Auteur
  • PersonId : 760684
  • IdRef : 151450021
Abdel Belaïd
  • Fonction : Auteur
In this paper, we propose an approach for the separation of overlapping and touching lines within handwritten Arabic documents. Our approach is based on the morphology analysis of the terminal letters of Arabic words. Starting from 4 categories of possible endings, we use the angular variance to follow the connection and separate the endings. The proposed separation scheme has been evaluated on 100 documents contains 640 overlapping and touching occurrences reaching an accuracy of about 96.88%.
Nazih_CAIP09.pdf (531.59 Ko) Télécharger le fichier
inria-00435250 , version 1 (24-11-2009)
Nazih Ouwayed, Abdel Belaïd. Separation of Overlapping and Touching Lines within Handwritten Arabic Documents. The 13th International Conference on Computer Analysis of Images and Patterns - CAIP 2009, Sep 2009, Munster, Germany. pp.237-244, ⟨10.1007/978-3-642-03767-2_29⟩. ⟨inria-00435250⟩
106 Consultations
589 Téléchargements
