Towards a Stable Decision-Making Middleware for Very-Large-Scale Self-Adaptive Systems. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
With the development of the communication infrastructures, the number of applications collaborating at large scale increases. To maintain, and continue to deliver services of good quality to the end-users, very-large-scale applications continuously adapt themselves, depending on the changes in their surrounding. Stabilization of the system thus becomes a keystone issue in the adaptation process, in order to reduce the system reconfiguration cost. Existing approaches, for the stabilization of very-large-scale systems, provide solutions that are partially efficient. For example, learning-based stabilization algorithms give good results in predicting application behaviors, but still suffer from their weak reactivity. In this paper, we propose an approach of combining different goals-oriented stabilization algorithms, in order to provide sustainable and efficient stabilization for large-scale systems.
towards-stable-decision-making-middleware.pdf (349.93 Ko) Télécharger le fichier
inria-00436013 , version 1 (25-11-2009)
  • HAL Id : inria-00436013 , version 1
Russel Nzekwa, Romain Rouvoy, Lionel Seinturier. Towards a Stable Decision-Making Middleware for Very-Large-Scale Self-Adaptive Systems.. BElgian-NEtherlands software eVOLution seminar (BENEVOL), Dec 2009, Louvain-la-Neuve, Belgium. ⟨inria-00436013⟩
205 Consultations
103 Téléchargements
