Local Protein Threading by Mixed Integer Programming
During the last decade, significant progresses have been made in solving the Protein Threading Problem (PTP). However, all previous approaches to PTP only perform global sequence–structure alignment. This obvious limitation is in clear contrast with the ”world of sequences”, where local sequence-sequence alignments are widely used to find functionally important regions in families of proteins. This paper presents a novel approach to PTP which allows to align a part of a protein structure onto a protein sequence in order to detect local similarities. We show experimentally that such local sequence–structure alignments improve the quality of the prediction. Our approach is based on Mixed Integer Programming (MIP) which has been shown to be very successful in this domain. We describe five MIP models for local sequence–structure alignments, compare and analyze their performances by using ILOG CPLEX 10 solver on a benchmark of proteins.
