BZR Contracts for Modular Discrete Controller Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We describe the extension of a reactive programming language with a behavioral contract construct. It is particularly dedicated to the programming of reactive control of applications in embedded systems, and involves principles of the supervisory control of discrete event systems. Our contribution is in a language approach where modular discrete controller synthesis (DCS) is integrated, and it is concretized in the encapsulation of DCS into a compilation process. From transition system specifications of possible behaviors, DCS automatically produces controllers that make the controlled system satisfy the property given as objective. Our language features and compiling technique hence provide correctness-by-construction in that sense, and enhance reliability and verifiability. An application domain particularly targeted at is that of adaptive and reconfigurable systems: closed-loop adaptation mechanisms enable flexible execution of functionalities w.r.t. changing resource and environment conditions. Our language can serve programming such adaption controllers. This paper particularly describes the compilation of the language. We present a method for the modular application of discrete controller synthesis on synchronous programs, and its integration in the BZR language. We consider structured programs, as a composition of nodes, and first apply DCS on particular nodes of the program, in order to reduce the complexity of the controller computation; then, we allow the abstraction of parts of the program for this computation; and finally, we show how to recompose the different controllers computed from different abstractions for their correct co-execution with the initial program. Our work is illustrated with examples, and we present quantitative results about its implementation.
RR-7111.pdf (361.31 Ko) Télécharger le fichier
inria-00436560 , version 1 (27-11-2009)
  • HAL Id : inria-00436560 , version 1
Gwenaël Delaval, Hervé Marchand, Eric Rutten. BZR Contracts for Modular Discrete Controller Synthesis. [Research Report] RR-7111, INRIA. 2009. ⟨inria-00436560⟩
187 Consultations
64 Téléchargements
