DUAL-BAND PRINTED DIPOLE ANTENNA ARRAY FOR AN EMERGENCY RESCUE SYSTEM BASED ON CELLULAR-PHONE LOCALIZATION - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microwave and Optical Technology Letters Année : 2004
Cyril Decroze
OSA
Thierry Monédière
  • Fonction : Auteur
  • PersonId : 915601
OSA
Bernard Jecko
  • Fonction : Auteur
  • PersonId : 914921
OSA
This paper describes the study of a novel dual-band antenna dedicated to be mounted on a helicopter for emergency localisation of cellular phones within the framework of the RNRT project called LUTECE. A folded dipole placed on a limited ground plane to allow wideband functionality and good radiation characteristics is proposed. Starting from this new topology, a directive array for the emission part and a circular disposition of five radiating elements with separated outputs for the receiving part are studied. All these developments are performed using our simulation code (FDTD method) along with experimental studies.
MOTL2.pdf (223.89 Ko) Télécharger le fichier
inria-00436616 , version 1 (27-11-2009)
  • HAL Id : inria-00436616 , version 1
Guillaume Villemaud, Cyril Decroze, Christophe Dall'Omo, Thierry Monédière, Bernard Jecko. DUAL-BAND PRINTED DIPOLE ANTENNA ARRAY FOR AN EMERGENCY RESCUE SYSTEM BASED ON CELLULAR-PHONE LOCALIZATION. Microwave and Optical Technology Letters, 2004, pp. ⟨inria-00436616⟩
368 Consultations
419 Téléchargements
