Polar Snakes: a fast and robust parametric active contour model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present in this paper a way to perform a fast and robust image segmentation and to track a contour along a sequence of images. Our approach is based on a dynamic deformable model. More precisely, we revisit the classical physics based-model to show the benefit of using a polar description to model the contour, in particular to cope with the well-known initialization problem. Indeed, we show that this way to proceed leads to diagonal and constant matrices in the equations of the snake evolution yielding therefore to a faster algorithm. Experimental results on image segmentation and contour tracking validate the efficiency of this new formulation.
Mots clés
Automatique
icip.pdf (187.59 Ko) Télécharger le fichier
inria-00629794 , version 1 (06-10-2011)
  • HAL Id : inria-00629794 , version 1
Christophe Collewet. Polar Snakes: a fast and robust parametric active contour model. IEEE Int. Conf. on Image Processing, Nov 2009, Le Caire, Egypt. pp.3013-3016. ⟨inria-00629794⟩
182 Consultations
364 Téléchargements
