Generic decoupled image-based visual servoing for cameras obeying the unified projection model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper a generic decoupled imaged-based control scheme for calibrated cameras obeying the unified projection model is proposed. The proposed decoupled scheme is based on the surface of object projections onto the unit sphere. Such features are invariant to rotational motions. This allows the control of translational motion independently from the rotational motion. Finally, the proposed results are validated with experiments using a classical perspective camera as well as a fisheye camera mounted on a 6 dofs robot platform.
2009_icra_tahri.pdf (812.44 Ko) Télécharger le fichier
inria-00436914 , version 1 (27-11-2009)
  • HAL Id : inria-00436914 , version 1
O. Tahri, Youcef Mezouar, François Chaumette, P. Corke. Generic decoupled image-based visual servoing for cameras obeying the unified projection model. IEEE Int. Conf. on Robotics and Automation, ICRA'09, 2009, Kobe, Japan, France. pp.1116-1121. ⟨inria-00436914⟩
171 Consultations
159 Téléchargements
