s'authentifier
version française rss feed
inria-00436920, version 1
Improvements on visual servoing from spherical targets using a spherical projection model
R. Tatsambon Fomena () a1, F. Chaumette () b1
IEEE Trans. on Robotics 25, 4 (2009) 874-886
Résumé : This paper is concerned with improvements to visual feature modeling using a spherical projection model. Three spherical targets are considered: a sphere, a sphere marked with a tangent vector to a point on its surface, and a sphere marked with two points on its surface. A new minimal and decoupled set of visual features is proposed for each target using any central catadioptric camera. Using the proposed set for a sphere, a classical control law is proved to be globally asymptotically stable in the presence of modeling errors and locally asymptotically stable in the presence of calibration errors, considering that perspective and paracatadioptric cameras were used. Simulation and experimental results with perspective, paracatadioptric, and fish-eye cameras validate the proposed theoretical results.
  • a –  Université de Rennes 1
  • b –  INRIA
  • 1 :  LAGADIC (INRIA - IRISA)
  • CNRS : UMR6074 – INRIA – Université de Rennes 1
  • Domaine : Informatique/Robotique
  • inria-00436920, version 1
  • oai:hal.inria.fr:inria-00436920
  • Contributeur :
  • Déposé pour le compte de :
  • Soumis le : Vendredi 27 Novembre 2009, 21:39:59
  • Dernière modification le : Lundi 30 Novembre 2009, 13:49:03
tous les articles de la base du CCSd...
