Opportunistic Adaptation Knowledge Discovery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Fadi Badra
Jean Lieber
Adaptation has long been considered as the Achilles' heel of case-based reasoning since it requires some domain-specific knowledge that is difficult to acquire. In this paper, two strategies are combined in order to reduce the knowledge engineering cost induced by the adaptation knowledge (CA) acquisition task: CA is learned from the case base by the means of knowledge discovery techniques, and the CA acquisition sessions are opportunistically triggered, i.e., at problem-solving time.
iccbr09.pdf (148.7 Ko) Télécharger le fichier
inria-00437693 , version 1 (01-12-2009)
Fadi Badra, Amélie Cordier, Jean Lieber. Opportunistic Adaptation Knowledge Discovery. 8th International Conference on Case-Based Reasoning - ICCBR 2009, Jul 2009, Seattle, United States. pp.60-74, ⟨10.1007/978-3-642-02998-1_6⟩. ⟨inria-00437693⟩
496 Consultations
253 Téléchargements
