5-colouring graphs with 4 crossings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We disprove a conjecture of Oporowski and Zhao stating that every graph with crossing number at most 5 and clique number at most 5 is 5-colourable. However, we show that every graph with crossing number at most 4 and clique number at most 5 is 5-colourable. We also show some colourability results on graphs that can be made planar by removing few edges. In particular, we show that if there exists three edges whose removal leaves the graph planar then it is 5-colourable.
RR-7110.pdf (330.23 Ko) Télécharger le fichier
inria-00437726 , version 1 (01-12-2009)
  • HAL Id : inria-00437726 , version 1
Rok Erman, Frédéric Havet, Bernard Lidicky, Ondrej Pangrac. 5-colouring graphs with 4 crossings. [Research Report] RR-7110, INRIA. 2009. ⟨inria-00437726⟩
155 Consultations
108 Téléchargements
