Application of the Microcanonical Multifractal Formalism to monofractal systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review E : Statistical, Nonlinear, and Soft Matter Physics Année : 2006
The design of appropriate multifractal analysis algorithms, able to correctly characterize the scaling properties of multifractal systems from experimental, discretized data, is a major challenge in the study of such scale invariant systems. In the recent years, a growing interest for the application of the microcanonical formalism has taken place, as it allows a precise localization of the fractal components as well as a statistical characterization of the system. In this paper, we deal with the specific problems arising when systems that are strictly monofractal are analyzed using some standard microcanonical multifractal methods. We discuss the adaptations of these methods needed to give an appropriate treatment of monofractal systems.
article.pdf (714.27 Ko) Télécharger le fichier
inria-00438520 , version 1 (01-04-2011)
Oriol Pont, Antonio Turiel, Conrad J. Perez-Vicente. Application of the Microcanonical Multifractal Formalism to monofractal systems. Physical Review E : Statistical, Nonlinear, and Soft Matter Physics, 2006, 74, pp.061110-061123. ⟨10.1103/PhysRevE.74.061110⟩. ⟨inria-00438520⟩
Collections
TDS-MACS
82 Consultations
149 Téléchargements
