s'authentifier
version française rss feed
inria-00438532, version 1
Gaussian and non-Gaussian processes of zero power variation
Francesco Russo () 123, Frederi Viens () a4
Résumé : This paper considers the class of stochastic processes $X$ which are Volterra convolutions of a martingale $M$. When $M$ is Brownian motion, $X$ is Gaussian, and the class includes fractional Brownian motion and other Gaussian processes with or without homogeneous increments. Let $m$ be an odd integer. Under some technical conditions on the quadratic variation of $M$, it is shown that the $m$-power variation exists and is zero when a quantity $\delta^{2}(r) $ related to the variance of an increment of $M$ over a small interval of length $r$ satisfies $\delta(r) = o(r^{1/(2m)}) $. In the case of a Gaussian process with homogeneous increments, $\delta$ is $X$'s canonical metric and the condition on $\delta$ is proved to be necessary, and the zero variation result is extended to non-integer symmetric powers. In the non-homogeneous Gaussian case, when $m=3$, the symmetric (generalized Stratonovich) integral is defined, proved to exist, and its Itô's formula is proved to hold for all functions of class $C^{6}$.
  • Domaine : Mathématiques/Probabilités
  • Mots-clés : Power variation – martingale Volterra convolution – covariation – calculus via regularization – Gaussian processes – generalized Stratonovich integral – non-Gaussian processes
  • inria-00438532, version 1
  • oai:hal.inria.fr:inria-00438532
  • Contributeur :
  • Soumis le : Jeudi 3 Décembre 2009, 20:38:51
  • Dernière modification le : Mardi 5 Janvier 2010, 15:01:35
tous les articles de la base du CCSd...
