High frequency analysis of the efficiency of a local approximate DtN2 boundary condition for prolate spheroidal-shaped boundaries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The performance of the second order local approximate DtN boundary condition, suggested by the authors in a previous work, is investigated analytically when employed for solving high-frequency exterior Helmholtz problems. This study proves that, in the high frequency regime, the reflected waves at the artificial boundary decay faster than $1/{(ka)^{15/8}}$ where $k$ is the wavenumber and $a$ is the semi-major axis of this boundary. Numerical results illustrate the accuracy and the efficiency of the proposed absorbing boundary condition when used for solving acoustic scattering problems in a domain-based formulation.
RR-7137.pdf (846.46 Ko) Télécharger le fichier
inria-00438845 , version 1 (04-12-2009)
inria-00438845 , version 2 (16-12-2009)
  • HAL Id : inria-00438845 , version 2
Hélène Barucq, Rabia Djellouli, Anne-Gaëlle Saint-Guirons. High frequency analysis of the efficiency of a local approximate DtN2 boundary condition for prolate spheroidal-shaped boundaries. [Research Report] RR-7137, INRIA. 2009, pp.38. ⟨inria-00438845v2⟩
212 Consultations
270 Téléchargements
