inria-00439284, version 2
Learning Color Names for Real-World Applications
Joost Van De Weijer
1Cordelia Schmid
a, 1Jakob Verbeek
a, 1Diane Larlus 1
IEEE Transactions on Image Processing 18, 7 (2009) 1512--1523
Résumé : Color names are required in real-world applications such as image retrieval and image annotation. Traditionally, they are learned from a collection of labelled color chips. These color chips are labelled with color names within a well-defined experimental setup by human test subjects. However naming colors in real-world images differs significantly from this experimental setting. In this paper, we investigate how color names learned from color chips compare to color names learned from real-world images. To avoid hand labelling real-world images with color names we use Google Image to collect a data set. Due to limitations of Google Image this data set contains a substantial quantity of wrongly labelled data. We propose several variants of the PLSA model to learn color names from this noisy data. Experimental results show that color names learned from real-world images significantly outperform color names learned from labelled color chips for both image retrieval and image annotation.
- a – INRIA
- 1 : LEAR (INRIA Grenoble Rhône-Alpes / LJK Laboratoire Jean Kuntzmann)
- CNRS : FR71 – CNRS : UMR5527 – INRIA – Laboratoire Jean Kuntzmann – Université Joseph Fourier - Grenoble I – Institut National Polytechnique de Grenoble (INPG)
- Domaine : Informatique/Apprentissage
- Mots-clés : Color naming – image annotation – image retrieval – probabilistic latent semantic analysis
- Versions disponibles : v1 (25-01-2011) v2 (11-04-2011)
- inria-00439284, version 2
- http://hal.inria.fr/inria-00439284
- oai:hal.inria.fr:inria-00439284
- Contributeur : Jakob Verbeek
- Soumis le : Lundi 11 Avril 2011, 14:45:33
- Dernière modification le : Lundi 11 Avril 2011, 15:09:25
Documents associés
Exporter
