Combining efficient object localization and image classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Hedi Harzallah
  • Fonction : Auteur
  • PersonId : 861132
Frédéric Jurie
Cordelia Schmid
  • Fonction : Auteur
  • PersonId : 831154
In this paper we present a combined approach for object localization and classification. Our contribution is two-fold. (a) A contextual combination of localization and classification which shows that classification can improve detection and vice versa. (b) An efficient two stage sliding window object localization method that combines the efficiency of a linear classifier with the robustness of a sophisticated non-linear one. Experimental results evaluate the parameters of our two stage sliding window approach and show that our combined object localization and classification methods outperform the state-of-the-art on the PASCAL VOC 2007 and 2008 datasets.
combine_localiz_cls.pdf (302.05 Ko) Télécharger le fichier
combine_localiz_cls-presentation.ppt (4.83 Mo) Télécharger le fichier
Format : Autre
inria-00439516 , version 1 (07-12-2009)
Hedi Harzallah, Frédéric Jurie, Cordelia Schmid. Combining efficient object localization and image classification. ICCV 2009 - 12th International Conference on Computer Vision, Sep 2009, Kyoto, Japan. pp.237-244, ⟨10.1109/ICCV.2009.5459257⟩. ⟨inria-00439516⟩
498 Consultations
1143 Téléchargements
