s'authentifier
version française rss feed
inria-00440337, version 2
Manifold Reconstruction using Tangential Delaunay Complexes
Jean-Daniel Boissonnat () 1, Arijit Ghosh (Auteur à contacter de préférence) 1
N° RR-7142 (2009)
Résumé : We give a provably correct algorithm to reconstruct a $k$-dimensional manifold embedded in $d$-dimensional Euclidean space. Input to our algorithm is a point sample coming from an unknown manifold. Our approach is based on two main ideas~: the notion of tangential Delaunay complex, and the technique of sliver removal by weighting the sample points. Differently from previous methods, we do not construct any subdivision of the embedding $d$-dimensional space. As a result, the running time of our algorithm depends only linearly on the extrinsic dimension $d$ while it depends quadratically on the size of the input sample, and exponentially on the intrinsic dimension $k$. To the best of our knowledge, this is the first certified algorithm for manifold reconstruction whose complexity depends linearly on the ambient dimension. We also prove that for a dense enough sample the output of our algorithm is isotopic to the manifold and a close geometric approximation of the manifold.
  • Domaine : Informatique/Géométrie algorithmique
  • Mots-clés : Tangential Delaunay complex – manifold learning – manifold reconstruction
  • Référence interne : RR-7142
  • Versions disponibles :  v1 (10-12-2009) v2 (16-09-2011)
  • inria-00440337, version 2
  • oai:hal.inria.fr:inria-00440337
  • Contributeur :
  • Soumis le : Vendredi 16 Septembre 2011, 14:56:24
  • Dernière modification le : Jeudi 5 Janvier 2012, 16:43:45
tous les articles de la base du CCSd...
