Cyclic Task Scheduling with Storage Requirement Minimization under Specific Architectural Constraints: Case of Buffers and Rotating Storage Facilities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
In this report, we study the exact and an approximate formulation of the general problem of one-dimensional periodic task scheduling under storage requirement, irrespective of machine constraints. We rely on the SIRA theoretical framework that allows an optimisation of periodic storage requirement \cite{Touati:PPL:04}. SIRA is based on inserting some storage dependence arcs ({\it storage reuse} arcs) labeled with {\it reuse distances} directly on the data dependence graph. In this new graph, we are able to bound the storage requirement measured as the exact number of necessary storage locations. The determination of storage and distance reuse is parametrised by the desired minimal scheduling period (respectively maximal execution throughput) as well as by the storage requirement constraints - either can be minimised while the other one is bounded, or alternatively, both are bounded \cite{siralina07,RR-INRIA-HAL-00436348}. This report recalls our fundamental results on this problem, and proposes new experimental heuristics. We typically show how we can deal with some specific storage architectural constraints such as buffers and rotating storage facilities.
PSSR.pdf (407.73 Ko) Télécharger le fichier
public_experimental_data.tar.bz2 (573.3 Ko) Télécharger le fichier
Format : Autre
inria-00440446 , version 1 (11-12-2009)
  • HAL Id : inria-00440446 , version 1
Sid Touati. Cyclic Task Scheduling with Storage Requirement Minimization under Specific Architectural Constraints: Case of Buffers and Rotating Storage Facilities. [Research Report] 2009. ⟨inria-00440446⟩
111 Consultations
88 Téléchargements
