Dependency Constraints for Lexical Disambiguation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We propose a generic method to per- form lexical disambiguation in lexicalized grammatical formalisms. It relies on de- pendency constraints between words. The soundness of the method is due to invariant properties of the parsing in a given gram- mar that can be computed statically from the grammar.
IWPT_dependency_constraints_for_LD.pdf (572.62 Ko) Télécharger le fichier
inria-00440795 , version 1 (11-12-2009)
  • HAL Id : inria-00440795 , version 1
Guillaume Bonfante, Bruno Guillaume, Mathieu Morey. Dependency Constraints for Lexical Disambiguation. 11th International Conference on Parsing Technologies - IWPT'09, Oct 2009, Paris, France. pp.242-253. ⟨inria-00440795⟩
97 Consultations
208 Téléchargements
