Dynamic Adaptation of the Master-Worker Paradigm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The size, heterogeneity and dynamism of the execution platforms of scientific applications, like computational grids, make using those platforms complex. Furthermore, today there is no effective and relatively simple solution to the programming of these applications independently of the target architectures. Using the master-worker paradigm in software components can provide a high level abstraction of those platforms, in order to ease their programming and make these applications portable. However, this does not take into account the dynamism of these platforms, such as changes in the number of processors available or the network load. Therefore we propose to make the master-worker abstraction dynamically adaptable. More specifically, this paper characterizes the master-worker paradigm on distributed platforms, then describes a decision algorithm to switch between master-worker implementations at run-time.
Dynamic_Adaptation_of_the_Master-Worker_Paradigm.pdf (243.93 Ko) Télécharger le fichier
inria-00440954 , version 1 (14-12-2009)
Françoise André, Guillaume Gauvrit, Christian Pérez. Dynamic Adaptation of the Master-Worker Paradigm. IEEE 9th International Conference on Computer and Information Technology, Oct 2009, Xiamen, China. ⟨10.1109/CIT.2009.40⟩. ⟨inria-00440954⟩
423 Consultations
217 Téléchargements
