On the Proof Complexity of Deep Inference - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Computational Logic Année : 2009
We obtain two results about the proof complexity of deep inference: (1) Deep-inference proof systems are as powerful as Frege ones, even when both are extended with the Tseitin extension rule or with the substitution rule; (2) there are analytic deep-inference proof systems that exhibit an exponential speedup over analytic Gentzen proof systems that they polynomially simulate.
OnPrComplDI.pdf (330.25 Ko) Télécharger le fichier
inria-00441211 , version 1 (15-12-2009)
Paola Bruscoli, Alessio Guglielmi. On the Proof Complexity of Deep Inference. ACM Transactions on Computational Logic, 2009, 10 (2), pp.34. ⟨10.1145/1462179.1462186⟩. ⟨inria-00441211⟩
84 Consultations
148 Téléchargements
