Quasipolynomial Normalisation in Deep Inference via Atomic Flows and Threshold Formulae - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
Jerábek showed that analytic propositional-logic deep-inference proofs can be constructed in quasipolynomial time from nonanalytic proofs. In this work, we improve on that as follows: 1) we significantly simplify the technique; 2) our normalisation procedure is direct, i.e., it is internal to deep inference. The paper is self-contained, and provides a starting point and a good deal of information for tackling the problem of whether a polynomial-time normalisation procedure exists.
QuasiPolNormDI.pdf (506.72 Ko) Télécharger le fichier
inria-00441213 , version 1 (15-12-2009)
  • HAL Id : inria-00441213 , version 1
Paola Bruscoli, Alessio Guglielmi, Tom Gundersen, Michel Parigot. Quasipolynomial Normalisation in Deep Inference via Atomic Flows and Threshold Formulae. 2009. ⟨inria-00441213⟩
136 Consultations
285 Téléchargements
