DiaSim: A Parameterized Simulator for Pervasive Computing Applications
Pervasive computing applications involve both soft- ware concerns, like any software system, and integration con- cerns, for the constituent networked devices of the pervasive computing environment. This situation is problematic for testing because it requires acquiring, testing and interfacing a variety of software and hardware entities. This process can rapidly become costly and time-consuming when the target environment involves many entities. In this demonstration, we present DiaSim, a simulator for per- vasive computing applications. To cope with widely heterogeneous entities, DiaSim is parameterized with respect to a description of a target pervasive computing environment. This description is used to generate both a programming framework to develop the simulation logic and an emulation layer to execute applications. Furthermore, a simulation renderer is coupled to DiaSim to allow a simulated pervasive system to be visually monitored and debugged.
Informatique ubiquitaire
