Improvement of Schedulability Analysis with a Priority Share Policy in On-Chip Networks
Priority-based wormhole switching with a priority share policy has been proposed as a possible solution for real-time on-chip communication. However, the blocking introduced by priority share complicates the analysis process. In this paper, we propose a new “per-priority” basis analysis scheme which computes the total time window at each priority level instead of each traffic-flow. By checking the release instance of each flow at the corresponding priority window, we can determine schedulability efficiently.
