Inferring Preoperative Reconstructed Spine Models to Volumetric CT Data through High-Order MRFs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2009
In this paper, we introduce a novel approach based on higher order energy functions which have the ability to encode global structural dependencies to infer articulated 3D spine models to CT volume data. A personalized geometrical model is reconstructed from biplanar X-rays before spinal surgery in order to create a spinal column representation which is modeled by a series of intervertebral transformations based on rotation and translation parameters. The shape transformation between the standing and lying poses is then achieved through a Markov Random Field optimization graph, where the unknown variables are the deformations applied to the intervertebral transformations. Singleton and pairwise potentials measure the support from the data and geometrical dependencies between neighboring vertebrae respectively, while higher order cliques are introduced to integrate consistency in regional curves. Optimization of model parameters in a multi-modal context is achieved using efficient linear programming and duality. A qualitative evaluation of the vertebra model alignment obtained from the proposed method gave promising results while the quantitative comparison to expert identification yields an accuracy of 1.8 +/- 0.7mm based on the localization of surgical landmarks.
RT-0374.pdf (1.3 Mo) Télécharger le fichier
inria-00442048 , version 1 (18-01-2010)
  • HAL Id : inria-00442048 , version 1
Samuel Kadoury, Nikolaos Paragios. Inferring Preoperative Reconstructed Spine Models to Volumetric CT Data through High-Order MRFs. [Technical Report] RT-0374, INRIA. 2009. ⟨inria-00442048⟩
159 Consultations
69 Téléchargements
