inria-00539957, version 1
Bounded-Curvature Shortest Paths through a Sequence of Points
Xavier Goaoc
1Hyo-Sil Kim 2Sylvain Lazard
1
N° RR-7465 (2010)
Résumé : We consider the problem of computing shortest paths having curvature at most one almost everywhere and visiting a sequence of $n$ points in the plane in a given order. This problem arises naturally in path planning for point car-like robots in the presence of polygonal obstacles, and is also a sub-problem of the Dubins Traveling Salesman Problem. This problem reduces to minimizing the function $F:\R^n\rightarrow\R$ that maps $(\theta_1,\ldots,\theta_n)$ to the length of a shortest curvature-constrained path that visits the points $p_1, \ldots, p_n$ in order and whose tangent in $p_i$ makes an angle $\theta_i$ with the $x$-axis. We show that when consecutive points are distance at least $4$ apart, all minima of $F$ are realized over at most $2^k$ disjoint convex polyhedra over which $F$ is strictly convex; each polyhedron is defined by $4n-1$ linear inequalities and $k$ denotes, informally, the number of $p_i$ such that the angle $\angle(p_{i-1},p_i,p_{i+1})$ is small. A curvature-constrained shortest path visiting a sequence points can therefore be approximated by standard convex optimization methods, which presents an interesting alternative to the known polynomial-time algorithms that can only compute a multiplicative constant factor approximation. Our technique also opens new perspectives for bounded-curvature path planning among polygonal obstacles. In particular, we show that, under certain conditions, if the sequence of points where a shortest path touches the obstacles is known then ``connecting the dots'' reduces to a family of convex optimization problems.
- 1 : VEGAS (INRIA Lorraine - LORIA)
- INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine
- 2 : Department of Electrical Engineering [Korea Advanced Institute of Science and Technology] (KAIST)
- Korea Advanced Institute of Science and Technology
- Domaine : Informatique/Géométrie algorithmique
- Référence interne : RR-7465
- inria-00539957, version 1
- http://hal.inria.fr/inria-00539957
- oai:hal.inria.fr:inria-00539957
- Contributeur : Xavier Goaoc
- Soumis le : Lundi 29 Novembre 2010, 11:51:57
- Dernière modification le : Mardi 14 Décembre 2010, 16:50:19
Documents associés
Exporter
